PegNet Mining and Future on Defi
Good day.
I want to find out what is everyone’s thoughts on PegNet and their LXRHash Algo. It has a really small 24h trading volume and a small Market Cap.
The benefit of it is that it is really easily minable which might be something that is mined in the background (my laptop has 8 threats and if I dedicated 6 of them with an i7-6820HQ), I get a Hashrate of 40 kH/s which is about 50-60 PEG a day. My current workflow on my laptop doesn’t require a lot of CPU power, so I can continue with my normal work without noticing the mining that is happening in the background. PS it isn’t profitable really if you just want to mine it for a return. That’s why my thoughts are just to keep it in the background of my normal works laptop which is something I would have done in any case.
Does anybody have any take on mining it and storing the coins in the hope of them going up in the future?
Regards
Can you share how you are mining PegNet with your GPU as far as i know it’s a CPU mining only.
