DASH, one of the leading coins, has been known for its stability, even after halving its value without much fluctuation. DASH mining machines are known for their stability in price and cost efficient due to their stable characteristics, especially the ANMINER D 9.
Introduction
ANTMINER D9 achieves a stunning 1770G hash rate, delivers reliable and powerful computing performance that dramatically saves energy and improves energy efficiency, and the new circuit configuration delivers an impressive 1.6J/G power efficiency, further improving the power efficiency ratio compared to the previous generation product D7. Standardized design for enhanced protection, ANTMINER D9 uses the same design as the flagship S19 series, compatible with modern data center new design to improve the shearer’s efficiency and safety.
Specifications
| MANUFACTURER | Bitmain |
| MODEL | Antminer D9 (1770Gh) |
| ALSO KNOWN AS | Antminer D9 1.77Th |
| RELEASE | February 2023 |
| SIZE | 316 x 430 x 570mm |
| WEIGHT | 16200g |
| NOISE LEVEL | 75db |
| FAN(S) | 4 |
| POWER | 2839W |
| INTERFACE | Ethernet |
| TEMPERATURE | 5 – 45 °C |
| HUMIDITY | 5 – 95 % |
Warranty
New model is with 180 days from the date of delivery.
Conclusion
If you are interested in Dash coin, you may consider ANTMINER D9. It is a high hashrate and efficient performance Dash miner. Meanwhile,the quality of D9 products is superior, the service is the best, immersion cooling system is also available.
Our Reputation is Your Guarantee!
Other websites with similar names may try to confuse you to think we are the same. Shenzhen Apexto Electronic Co., Ltd has been in the Blockchain mining business for more than seven years. For the last 12 years, Apexto has been a Gold Supplier. We have all kinds of ASIC miners, including Bitmain Antminer, WhatsMiner, Avalon, Innosilicon, PandaMiner, iBeLink, Goldshell, and others. We also have launched a series of products of oil cooling system and water cooling system.
New Antminer D9 (1770G) from Bitmain mining X11 algorithm with a maximum hashrate of 1770Gh/s for a power consumption of 2839W
