Ready to pull the trigger on my 1st purchase but still don’t know where to begin. budget of 500 - 1000 and truthfully just need a straight answer on what to buy. Can get a used MICROBT WHATSMINER M21S BITCOIN MINER (54TH/S), should i do it?
Are you going to get it hosted or do you have the power hook ups ready to plug and hash?
Your electrical situation is a must know if you want a straight answer. If you have a 220v plug somewhere, that would be best in terms of options
You need an l6 receptacle 10 gauge wire and a 30 amp breaker wired for 240v . Then a pdu. With c13 and c19 plugs. Then you’re probably going to need a C13 to C14 wire to plug the miner in. You need an license electrician to work in the service panel
You really need a miner that is in the 20’s j/th to make any money after the having. And electricity below 10c. It might be best to just buy the coin.
