I switched my KD Box over from DXPool to Poolflare going to zelcore this morning around 6am. Using the .net address. I switched because I was getting 70% rejects. Anyone know how long it takes for the first payout? I’m in the USA.
Poolflare Payout is twice a day around 12 UTC time and UTC +12 hours but minimum payout is 0.5 KDA please keep this in mind. Please note Poolflare is sending payout to Chain 0 so make sure you are owner of that chain otherwise you are sending money to somebody else. With KDA each chain can be controlled by different public key /keys and this is where people get lost
BTW please find attached picture and example of “stolen” chain.
As you can see account has same number as public key on chain 0 but some MF stole chain 1 under "mine"account with his public key. So in case I would send money from Kucoin which will by default go to chain 1 I would send money to somebody else. I think this is the reason Kucoin suspended withdrawals cause smart asses started to hijack Chain 1 of created accounts… Kadena fix this by k:Account where you can not controle Chain with public key different from account public key
Sorry I think my answer is going way further from your question
I received my 1st payout from poolflare this morning @6am cst
I’m sure the above UTC time correlates with that but since we don’t generally ever see it…I included the less global U.S. time zone
Much appreciated.
Saved me a trip to Google
Is there a way to know if I entered all my info correctly into poolflare to payout on my zelcore wallet? I set it up around 5:15am eastern time. I used kda-us.ss.poolflare.net: 443 as the pool and entered my k: wallet address as the user name. Kd box shows it’s hashing. Only 1% reject rate compared to dxpool.
If you can find your machine hashing on the poolflare web under the number of your wallett it should be set it a right way. There was a payout 25 min ago so you should see in payout section on poolflare web if you accumulated over 0.5 KDA. It will take some time to be available in the wallet.
I found it. Thank you. It looks like I made .865 KDA in the last 12 hrs. So much better than dxpool.
