Power cable for antminer s19j pro +
Hi guys, don’t know if you can help me. I’ve had a antminer s19j pro+ delivered today. Unfortunately it hasn’t come with a power cord (don’t know if that’s normal) what power cord do you suggest I get and where from? Needs to be a uk plug.
Thanks
Ashley
220-240v rated c13 cable. Or did you get this power input?
Didn’t get any power cable with the miner. Do I need two separate cables or one plug and a splitter? Would you add serge protection or is it ok just plugged into the mains in the uk?
You’ll want two 220-240v rated c13 cables. I’d recommend using a pdu with surge protection but is not necessary.
Tripp Lite Basic PDU, 30A, 20 Outlets (16 C13 & 4 C19), 200/208/240V, L6-30P Input, 15’ Cord, 1U Rack-Mount Power, 5 Year Warranty (PDU1230) https://a.co/d/h7gF3F7
Something like this with a UK plug.
There’s probably a Currys near you from what I understand about the UK. You could go there and pay too much for 2 of these
https://www.currys.co.uk/products/logik-lkettle22-kettle-power-adapter-cable-1.8-m-10230800.html
Cheers for your advice guys got two from local shop for £10. Up and running now
Happy mining!!
