For running 240v what do you do to make sure you have clean power?
something like that @NachLibre 241831409_1602997713368716_7683171292840882066_n|690x395
Clean install.
Do you have surge protection or anything else?
Wow I ran a 60amp service 75 ft from the main panel, installed a sub panel and dedicated 240v circuits and a dedicated 30amp pdu receptacle for less than half of that. I am an electrician though so no labour charge
You can use a surge protector if you want For insurance personally don’t. Never been an issue historically in my region
You run them at 240?
measured at 250v from wall
Stopped down at the warehouse tonight to draw up some plans. Got 100amp dedicated and was suggested a surge protector would be a good option.
The guy doing the wiring showed me a breaker that also has a surge protector for $170. Another option is a breaker box, surge protector for an outdoor ac condenser.
Things are moving along, thanks for the input so far, I showed him your setups and he liked them.
