Power cord and PDU recommendations for S19J Pro 104 Th/s 3120W
Hey folks,
I have the above arriving on Monday (fingers crossed) and am looking for what power cords/PDU’s to get.
I’m in the US, will have a 220 30Amp service with a Leviton 2620 30 Amp, 250 Volt, Flush Mounting Locking Receptacle.(or other recommendation?)
Any other recommendations for setting it up?
Thanks much!
G
Disclaimer: I am not an electrician
But I am experienced.
I use this unit for my farm. It’s pricy but allows for monitoring of the power both from its little screen and via a web interface. You can get the same thing without the monitoring and web stuff for about $200 less I think.
Tripp Lite PDU Monitored 208/240V 30A 36 C13; 6 C19 Outlets L6-30P LX Interface 10 ft Cord 0URM TAA (PDUMNV30HV2LX) https://smile.amazon.com/dp/B077B9MQD1/ref=cm_sw_r_cp_api_glt_fabc_AAJ7TTM8PDNGW7PK9PNN
Then for cables you’ll need two of the following:
C14 to C13 Power Cord - 3 Foot, Red, 15A, 250V, 14 AWG / 14/3 SJT Cable, IEC 60320 - Iron Box Part # IBX-2804-03 https://smile.amazon.com/dp/B00CEYXPC0/ref=cm_sw_r_cp_api_glt_fabc_CE4E19X8KF8D8CK2PS3J?psc=1
Those cables are 3’ long, you can get longer ones if you need. I like to use diff colored cables by miner. So red for one rig, blue for another.
I’m not posting affiliate links bc idk if I can. And if I’m not allowed to post Amazon links at all please let me know.
A little warning, by my math, you can only do 2 of those rigs per PDU and 30A/240 circuit. They eat some juice.
Hope that helps. If you have questions, lmk.
Thanks much!
G
I am currently waiting on my PDU today. AMAZON hurry! Have had to stare and sweet talk my S19J PRO all week waiting for the PDU. i got the Tripp lite Basic 30A 20 outlet. I have an electrical apprentice license and worked in the commercial side of it. This will be sufficient. you can get outside monitoring Devices that will save you a bit. it is convenient having it all in the same package though
Can you throw up a link of the pdu you used? I’m looking for other options.
Amazon.com: Tripp Lite Basic PDU, 30A, 20 Outlets (16 C13 & 4 C19), 200/208/240V, L6-30P Input, 15’ Cord, 1U Rack-Mount Power, 5 Year Warranty (PDU1230) : Electronics
