I just realized that the main fans on power supplies are sucking in air and not blowing out air. Should I be facing the fans down then? Here is my current setup.
Fans are usually installed downward in pc towers. That said, it’s a fan and it’s only got to move the air a few inches probably aren’t going to hurt anything either way.
