Which is more profitable from your guys personal experiences? Currently mining on claymore/2miners
pps give you stable earnings and lower profit,pplns give higher eraning depend of pool luck. 2miners is better run phoenix more stable of claymore lower dev fees
The miner crashes within hours on phoenix and spews stale shares (5700xt) no oc
only rig to have the issue. I’ll stick with 2miners , thanks for the help
you have overcloked to much your gpus if crashing or use wrong settings for phoenix
Overclock settings untouched, one of the GPUs is originally a 5700 that I flashed into an xr. I thought it may be the problem. Hard to tell as phoenix doesn’t seem to give info on what card is causing the stale shares. I’ll just add them one at a time until I find the culprit I guess cheers
run card on claymore second on phoenix and you will see with one crash. in your case shut crashing moded card
