Had my rig up and running just fine with 2 GPUs. Added a 3rd and saw no issues. Once I added the 4th, the mining program runs for a few minutes then quits unexpectedly. All drivers are up to date and mobo is showing no errors when I boot up. Issue only occurs once I’ve been mining for a few minutes.
- Currently using nanominer
- All GPUs are Geforce GTX 1660s
- Mobo is ASUS B250 Mining Expert
Tried to add the autoUpdate=true in nanominer config file in case there were any updates needed. Seeing no change in the issue.
Wondering if I need to adjust settings in the asus bios? I’ve reset to default with no luck then tried setting the PCIE settings to Gen1. Same issue occurs.
I’ll keep mining with the 3 GPUs for the time being and continue to troubleshoot. My thoughts are something is needed in the nanominer config files but I haven’t found a solution yet. Any suggestions are appreciated!
