Hey guys and Vosk, i have a problem with a ks5m iceriver miner it shows 0 th and abnormal hash for 5 min. I tried every possible thing and it didn’t work. Please any if can suggest something. Please any advice will be good.
Flash firmware to newest and also check your fans
I’ve had similar issue and got it resolved
Tried it, didn’t work, could it be router blocking traffic?
Hey, try changing your mining pool. This happened to me with one of my KS3M’s. It was wild because I had been using that pool for months and then randomly it was working for one and not the other. Change it to a completely different pool and see if that helps! ![]()
My router did something weird to me Once before where everything on my network was Perfectly fine except my miner The router was seeing the miner But there was no sending or receiving packets data Nothing I spent hours trying to figure it out Went through all the settings diagnosed the entire router couldn’t Figure it out so I had no other choice factory, reset my router. Everything came back up and running perfectly fine never had the problem again.
Don’t know what caused it.
Yes tried it didn’t work sadly, thank you though!
Also when I first started mining with my s19jpro I thought I had the right gauge wire for the L7 plug. Which was technically the bear minimum gauge wire Which, after a while of mining it gave me a problem. It was showing errors like what you’re getting. So I went up to 6 gauge wire for the L7 plug. And that actually took care of the problem Just a thought. Also, if you have a spare main board like brains or epic board tried out.
To test out the theory, you can always use the L7 dryer plug if you have one.
