Hi i have a problem with my rx 570 8gb for a few day
Im new to mining and i buy 6 rx570 (3 asus and 3 msi) each have 8 gb or ram they all brand new and i can’t start mining i try with nicehash and i can not benchmark they send me error .
I try with cudominer they give me error all jobs failling …
I try with cudomimier os and again i can not conect to a job .
I try all these step with my 1070 ti and all works fine can someone please help me !
If that doesnt work, then you may need to manually input your speed into the algo thru the Nicehash benchmark. I had to. After one of their last updates, none of my AMD (580, 5500, Radeon VII) would auto bench. I just entered in their max Mhs into each cards algo settings and they have been working fine. Frankly, i feel like those algorithms are targeting AMD chipsets, but i have no actual proof.
switch not need to move same as compute if you use correct drivers. my rx 580 run without touch switch or on windows change to compute, mining os are plug and play already set up compute, switch same dont do nothing you switch or not nothing different
