Which psu is suites for Goldshell KD Box II? 550W, 650W, 750W and 850W …
I wouldn’t use any of them buy a real asic psu y risk burning your house down for extra 20$
On my small farm I personally use no more than 5 KD boxes on 1 bitmain APW7 in my office mine
And a 750w PSU for 2 mini doge boxes
So with a small kd single box a smaller PSU should be fine depending on conditions
if you oversize your PSU by 20-30% they’ll run at a higher efficiency. for example if you have 1000W miner use a 1200-1400W psu. In any case I would recommend to always have 10% overhead to avoid running the PSU at 100% capacity all the time, or where it’s sensitive to faults like over current.
that being said I would never exceed 12.5Amps (1500W) on any residential circuit, and if you live in an old ass house with old wiring I wouldn’t exceed 7.5A (900W).
