Question for experianced miners ONLY>
What is the maximum ping acceptable for pool asic mining and separately for solo mining. I understand AI can offer this answer however it is not as accurate compared to the experience of a actual person whom mines.
< 20ms great
< 50ms won’t impact mining rewards
Hi Badgerlandcrypto,
Is there any point to pool mine with a ping between 97-110?
shoot me a dm
I have a question I got an S19 pro and I got a transformer 3 US plugs on top (110-120v) and 3 EU plugs on the bottom (220-240) when I use the US plug it doesn’t turn on and I have EU plugs but when I use them my circuit breaker trips how can I solve this
You need 220v American plugs. The European plugs run higher I believe and are at 240v which might be why your tripping breakers.
