Hello,
My question is if the amount of coins you earn while mining goes up at the same rate that the has rate goes up.
Example: I’m currently using Unmineable to mine Dogecoin using 2 Nvidia 1070 gpu’s. I’m averaging 42 MH’s and earning 15 Doge coins a day. I’m looking to get an ASIC miner (Antminer L3+). It’s published hash rate is ~500Mh/s. Those number indicate that the ASIC miner is 12 times faster than my gpu’s. Does it stand to reason that I would be earning 12 times the number of Doge? This would be 180 Doge each day.
Thanks for your assistance
Mark
