Hi Gus,
I am running a rig with 6 of theses and I am only able to get over 37 MH/S.
Is anyone having any luck getting 42 or +??
PS, I have watched the Youtube video about flashing the bios and it doesn’t work… so any suggestions?
Hi Gus,
what clock/undervolt settings are you using and what is preventing you from raising them? I am guessing its probably memory temperature? On my 5600xt mech (terrible card btw) I undervolted the memory (not controller) and set a fixed fan speed and it dropped the temp to low 80s.
If Dual Bios, check that you are using performance mode.
Also , you need to be in Compute mode but I don’t know how to set that.
Try TeamRedMiner
Literally just fixed this from this video: BIOS MOD for the RX 5600 XT For Ethereum Mining! - YouTube I used the modded bios linked in the description, rebooted and BAM! 43Mhs! I did set the fan to 80% though because it got hot otherwise, I read that overheating was common on them.
At 80% fan speed it stays at around 63 degrees.
You can set compute mode through the Adrenaline software, I believe it needs to be Windows 10 OS mkinimum because it would give the option under Windows 7.
If you use a mining OS (HiveOS is what I use) the mining software seems to do it automatically.
