I’m being trying to set up my 2 AMD Radeon VII mining rig in HiveOS and everything runs good but the temperatures are always 8 to 10 degrees hotter compared to windows whit exactly the same overclock settings. Does anyone have any idea of why is this happening ?
It is know that you can get different values from different monitoring softwares but I am not sure which is more accurate it could also be the miner you are using maybe try to change your flight sheet to a different miner I have also found on certain algo I have to reduce the power to my GPU or they run hotter than normal. hope this helps
