Released RXD-RX0-260G-100W with PSU!
ICERIVER RX0 – Developed by ICERIVER , this home-friendly, silent mining machine uses the SHA512256d algorithm , delivering a standard hashrate of 260 GH/s with a rated power consumption of 100W . Its dimensions are 200x194x74mm , and it weighs 2.5 kg . The compact device is equipped with two fans and operates at a noise level of only 40 dB , making it an ideal choice for home mining setups. It supports Ethernet connectivity, ensuring seamless performance in home environments.
