Hi, does anybody know of a power socket that can be timed for on / off and allow me to turn it on / off remotely, while I am out, from my phone?
Ah, Forgot to say that I am in the UK ![]()
Cheers
Cheers
Your probably want a switch pdu they give you remote access just l ow anything that does that stuff isnโt cheap
I use the Pros, but this is probably good for you:
https://www.shelly.com/en-ie/products/product-overview/shelly-plug
Or there are all sorts of Tuya ones on AliExpress. Shelly are the best Iโve used, and this one is 16A so good for just about anything
