Repair my Antminer S9
Hey Team,
I got around 12 Antminer S9 on ebay which looked really good and most of them are working fine.
One device shuts off after 2-20 minutes while the power supply fans keep running. Question: might there be a broken “solder joint”?
Issue with two other miners: only two hashboards running. I am thinking about either buying a chip repair kit or another miner to fix the hashboards entirely. Opinions here?
Try resetting the miner that shuts off after 2-20 mins could have overheated previously and just needs a reset.
If that does not work why not use it for parts and switch the haahboards out for the ones that don’t work on the other two.
This is the log of one of the miners:
Mem: 33256K used, 462276K free, 0K shrd, 838336K buff, 838384K cached
CPU: 4.7% usr 4.7% sys 0.0% nic 90.4% idle 0.0% io 0.0% irq 0.0% sirq
Load average: 0.19 0.14 0.06 1/69 12420
PID PPID USER STAT VSZ %VSZ CPU %CPU COMMAND
1583 1579 root S 3668 0.7 0 4.7 {averager} /hive/sbin/bash /hive/bin/averager interactive
12417 12416 www R 2836 0.5 0 4.7 top -b -n 1
11848 1 root S 43588 8.7 1 0.0 /usr/bin/bmminer --fixed-freq --no-pre-heat --version-file /usr/bin/compile_time --api-listen --default-config /config/bmminer.conf
1489 1486 root S 4224 0.8 0 0.0 {agent} /hive/sbin/bash /hive/bin/agent
1490 1 root S 4156 0.8 1 0.0 {controller} /hive/sbin/bash /hive/bin/controller
1874 1871 nobody S 3852 0.7 0 0.0 nginx: worker process
1732 1583 root S 3832 0.7 0 0.0 {averager} /hive/sbin/bash /hive/bin/averager interactive
1735 1583 root S 3800 0.7 0 0.0 {averager} /hive/sbin/bash /hive/bin/averager interactive
1733 1583 root S 3796 0.7 0 0.0 {averager} /hive/sbin/bash /hive/bin/averager interactive
12419 1583 root S 3668 0.7 1 0.0 {averager} /hive/sbin/bash /hive/bin/averager interactive
1857 1 root S 3596 0.7 1 0.0 perl /sbin/watchdog.pl
1858 1 root S 3596 0.7 1 0.0 perl /sbin/watchdog_restart.pl
1871 1 root S 3532 0.7 0 0.0 nginx: master process /usr/bin/nginx
1258 1 www S 3148 0.6 1 0.0 /usr/sbin/lighttpd -f /etc/lighttpd.conf
2260 1 root S 3084 0.6 0 0.0 /usr/bin/ntpd -p /var/run/ntp.pid -g
1851 1 root S 2840 0.5 0 0.0 /sbin/getty 115200 ttyPS0
1852 1 root S 2840 0.5 0 0.0 /sbin/getty 38400 tty1
1853 1 root S 2836 0.5 0 0.0 {monitorcg} /bin/sh /sbin/monitorcg
1291 1 root S 2836 0.5 1 0.0 /usr/sbin/crond
1861 1 root S 2836 0.5 1 0.0 /usr/sbin/crond
2125 1 root S 2836 0.5 1 0.0 udhcpc -b -t 10 -A 10 -x hostname antMiner -i eth0
12416 1258 www S 2836 0.5 1 0.0 /bin/sh /www/pages/cgi-bin/monitor.cgi
12418 12416 www S 2836 0.5 1 0.0 /bin/sh /www/pages/cgi-bin/monitor.cgi
12129 1853 root S 2704 0.5 0 0.0 sleep 20s
1486 1 root S 2600 0.5 1 0.0 {screen} SCREEN -dm -S agent -h 300 agent
1579 1 root S 2600 0.5 1 0.0 {screen} SCREEN -dm -S averager -t Client for ASICs: Average Hashrate Aggregator v0.3.5 -h 300 averager interactive
1839 1 root S 2484 0.5 1 0.0 /usr/bin/monitor-recobtn /usr/bin/factory_config_reset.sh
1 0 root S 1688 0.3 0 0.0 init [5]
1115 1 root S 1676 0.3 1 0.0 /usr/bin/monitor-ipsig
7 2 root SW 0 0.0 1 0.0 [rcu_preempt]
1201 2 root SW 0 0.0 1 0.0 [kworker/1:2]
6 2 root SW 0 0.0 1 0.0 [kworker/u4:0]
3 2 root SW 0 0.0 0 0.0 [ksoftirqd/0]
14 2 root SW 0 0.0 1 0.0 [ksoftirqd/1]
1009 2 root SW 0 0.0 0 0.0 [kworker/0:1]
1085 2 root SW 0 0.0 0 0.0 [ubi_bgt0d]
10 2 root SW 0 0.0 0 0.0 [migration/0]
13 2 root SW 0 0.0 1 0.0 [migration/1]
18 2 root SW 0 0.0 0 0.0 [kdevtmpfs]
1087 2 root SW 0 0.0 1 0.0 [ubifs_bgt0_0]
2 0 root SW 0 0.0 0 0.0 [kthreadd]
4 2 root SW 0 0.0 0 0.0 [kworker/0:0]
5 2 root SW< 0 0.0 0 0.0 [kworker/0:0H]
8 2 root SW 0 0.0 0 0.0 [rcu_sched]
9 2 root SW 0 0.0 0 0.0 [rcu_bh]
11 2 root SW 0 0.0 0 0.0 [watchdog/0]
12 2 root SW 0 0.0 1 0.0 [watchdog/1]
15 2 root SW 0 0.0 1 0.0 [kworker/1:0]
16 2 root SW< 0 0.0 1 0.0 [kworker/1:0H]
17 2 root SW< 0 0.0 1 0.0 [khelper]
19 2 root SW 0 0.0 0 0.0 [kworker/u4:1]
223 2 root SW< 0 0.0 0 0.0 [writeback]
225 2 root SW< 0 0.0 1 0.0 [bioset]
227 2 root SW< 0 0.0 1 0.0 [kblockd]
243 2 root SW 0 0.0 0 0.0 [khubd]
258 2 root SW< 0 0.0 0 0.0 [edac-poller]
349 2 root SW< 0 0.0 0 0.0 [rpciod]
350 2 root SW 0 0.0 1 0.0 [kworker/1:1]
360 2 root SW 0 0.0 1 0.0 [khungtaskd]
365 2 root SW 0 0.0 1 0.0 [kswapd0]
366 2 root SW 0 0.0 1 0.0 [fsnotify_mark]
367 2 root SW< 0 0.0 1 0.0 [nfsiod]
1008 2 root SW< 0 0.0 1 0.0 [xemacps]
1024 2 root SW< 0 0.0 0 0.0 [kpsmoused]
1080 2 root SW< 0 0.0 0 0.0 [deferwq]
1139 2 root SW 0 0.0 0 0.0 [kworker/u4:2]
1869 2 root SW 0 0.0 0 0.0 [kworker/0:2]
Have you tried reflashing the firmware.
return it. seller can say all he/she wants but if you miner isn’t as described, you can return it. ebay doesn’t care about sellers at all. seller will have no choice but to refund you the money. if seller resists, ebay will forcefully reverse the transaction. seller will have to pay shipping fees for a return. Unless you bought these at a steep discount, i wouldn’t want to go through hassles of trying to deal with machines that are defective and trying to fix them, especially USED ones. at least new machines have warranties, but not used ones. Learn my my mistake from both buying and selling on ebay.
