What is the minimum internet speeds needed to run a couple of miners? I live in a rural area and only get 5mbps download and .5 upload. Will this work or will I need to upgrade to some kind of satelite internet?
Thanks all
My experience is it doesn’t take much. Your internet is pretty limited though. Unless you’re talking Starlink, sat internet sucks.
Take your PC and start pinging some of the pools. I bet youll be ok.
