Is there a chart somewhere that shows the miners that can run on normal electricity vs the 220 higher voltage?
I don’t have a chart but I can say that a typical 15 amp 120v US outlet is 1800 watts. You want to use the 80% rule so that is 1440 watts max. Anything higher than that and you’ll need a higher power outlet.
To calculate watts:
Amps x volts = watts.
https://www.rapidtables.com/calc/electric/watt-volt-amp-calculator.html
