Currently I have 3 dodge mini box miners running on my 1000 watt PSU (Seasonic GX-1000 rated 80+ gold). Each box miner is 235watts and I plan on adding a 4th box to my setup. Can I use the rest of the wattage on my PSU which will max it out at 1000watts? Or does the 80% electricity rule apply here also? Thanks for your advice, everyone has been so helpful.
The video was very informative. Thank you I saved it for reference.
