I’ve followed all the steps for bios mods and patch, even some overclock and underpowering to some extent. However, still only achieving 26.8 MH/s. Should this be fine to just stay at this level or continue to try and push for that 30+ range?
Current:
PowerColor Red Devil RX 580 8GB
Windows 10 Nicehash
Core: 1175 / Mem: 2150 / Voltage: 850
have you increased the memory refresh rate (rxboost)? If not that should get you some more MH/s. I think the default is like 5. Try to set it around 30 and see if the cards are stable. I was able to push my samsungs up to 35
If your card running at 75 Celsius i would recommend adding a fan or something to cool it down (air flow). Maybe change the pads if it is an older hard mined card. Because in the long run, i dont think you would like the card running at 75 Celsius.
So I attempted the -rxboost and from what I can see/tell is that I’m getting about same hashrates w/ or w/o the boost. If anything, the temps ran higher on the cards…so I think I can probably chalk this up to just these cards may not reach that 30+ range and be happy with what I am getting.
I attempted 20/30/&35 rxboost. Temps on the cards shot up to 75-80C
