Test System Spec - AMD Ryzen 5900X, Asrock X570 Taichi Razer, Corsair H150i Pro RGB, G.Skill TridentZ RGB 3200 Mhz, Corsair MP600 1TB Nvme, EVGA XC RTX 3060, Seasonic 1200 Watt PSU
Hey All,
I first tested the base performance live on my channel, SerpentX Special Forces. I continued testing off the camera but here is what I got so far, however, please feel free to share your data or findings below with the community. Still, even though the RX 6000 series has been out for a while, not all miners are supported at this time and Devs are still releasing updates. Please take time to watch videos and see the notes below.
Thanks
- Vega
Summary Video - https://youtu.be/yotbpDouncw
Live Stream Link: https://youtu.be/84DLsLRTcrQ
**Note: with this newer generation of AMD GPU’s there are “Memory Timings - Default” and “Memory Timings - Fast”. Not all Algos will see a performance boost with Fast timings, but I added it to the data. Drivers are still not as great, crashes will happen and you will have to re-apply your clocks, and the power draw readings are all over the place. HWinfo, AMD Radeon software, and the Mining programs themselves all report something different, so the Power draw below was taken from a Kilowatt meter.
Phoenix Miner 5.5c - ETH - Ethereum
| 44.2 Mhs | 2615 core / 2000 mem | vcore 1200 / PL 0 | 185 Watt - (Default Timings) |
| 47.5 Mhs | 2615 core / 2150 mem | vcore 1200 / PL 0 | 210 Watt - (Fast Timings) |
| 47.3 Mhs | 2050 core / 2150 mem | vcore 950 / PL 0 | 150 Watt - (Default Timings) |
| 48.7 Mhs | 2050 core / 2150 mem | vcore 950 / PL 0 | 150 Watt - (Fast Timings) |
Phoenix Miner 5.5c - ETC - Ethereum Classic
| 44.5 Mhs | 2615 core / 2000 mem | vcore 1200 / PL 0 | 185 Watt - (Default Timings) |
| 45.10 Mhs | 2615 core / 2150 mem | vcore 1200 / PL 0 | 210 Watt - (Fast Timings) |
| 47.8 Mhs | 2050 core / 2150 mem | vcore 950 / PL 0 | 150 Watt - (Default Timings) |
| 48.4 Mhs | 2050 core / 2150 mem | vcore 950 / PL 0 | 150 Watt - (Fast Timings) |
Team Red Miner 0.8.1.1 - KawPow - Ravencoin
| 22.4 Mhs | 2615 core / 2000 mem | vcore 1200 / PL 0 | 225 Watt - (Default Timings) |
| 23.10 Mhs | 2450 core / 2050 mem | vcore 1100 / PL 0 | 200 Watt - (Fast Timings) |
| 22.75 Mhs | 2150 core / 2100 mem | vcore 1050 / PL 0 | 175 Watt - (Fast Timings) |
| 23.05 Mhs | 2050 core / 2150 mem | vcore 950 / PL 0 | 160 Watt - (Fast Timings) |
NB Miner 36.1 - Octopus - Conflux
| 28.47 Mhs | 2615 core / 2000 mem | vcore 1200 / PL 0 | 225 Watt - (Default Timings) |
| 27.65 Mhs | 2450 core / 2050 mem | vcore 1150 / PL 0 | 190 Watt - (Fast Timings) |
| 24.55 Mhs | 2150 core / 2100 mem | vcore 1050 / PL 0 | 170 Watt - (Fast Timings) |
| 23.08 Mhs | 2050 core / 2150 mem | vcore 950 / PL 0 | 145 Watt - (Fast Timings) |
Note: New NBminer 37.1 doesn’t work but the old one does, however, get a lot of rejected shares.
Team Red Miner 0.8.1.1 - Firo (Zcoin) - MTP
| 3.74 Mhs | 2615 core / 2000 mem | vcore 1200 / PL 0 | 225 Watt - (Default Timings) |
| 3.81 Mhs | 2450 core / 2050 mem | vcore 1150 / PL 0 | 210 Watt - (Fast Timings) |
| 3.44 Mhs | 2150 core / 2100 mem | vcore 1050 / PL 0 | 175 Watt - (Fast Timings) |
| 3.30 Mhs | 2050 core / 2150 mem | vcore 950 / PL 0 | 160 Watt - (Fast Timings) |
NB Miner 37.1 - ProgPoW_Sero - Sero
| 21.30 Mhs | 2615 core / 2000 mem | vcore 1200 / PL 0 | 225 Watt - (Default Timings) |
| 21.76 Mhs | 2450 core / 2050 mem | vcore 1100 / PL 0 | 200 Watt - (Fast Timings) |
| 19.24 Mhs | 2150 core / 2100 mem | vcore 1050 / PL 0 | 170 Watt - (Fast Timings) |
| 19.46 Mhs | 2050 core / 2150 mem | vcore 950 / PL 0 | 165 Watt - (Fast Timings |
Gminer 2.50 - Equihash 144,5 - Bitcoin Gold
| 63.7 Sols | 2615 core / 2000 mem | vcore 1200 / PL 0 | 210 Watt - (Default Timings) |
| 61.6 Sols | 2450 core / 2050 mem | vcore 1150 / PL 0 | 160 Watt - (Fast Timings) |
| 54.5 Sols | 2150 core / 2100 mem | vcore 1050 / PL 0 | 120 Watt - (Fast Timings) |
| 52.1 Sols | 2050 core / 2150 mem | vcore 950 / PL 0 | 120 Watt - (Fast Timings) |
Gminer 2.50 - Equihash 125,4 - Flux (Zel)
| 39.2 Mhs | 2615 core / 2000 mem | vcore 1200 / PL 0 | 210 Watt - (Default Timings) |
| 39.8 Mhs | 2450 core / 2050 mem | vcore 1150 / PL 0 | 160 Watt - (Fast Timings) |
| 36.6 Mhs | 2150 core / 2100 mem | vcore 1050 / PL 0 | 125 Watt - (Fast Timings) |
| 34.2 Mhs | 2050 core / 2150 mem | vcore 950 / PL 0 | 120 Watt - (Fast Timings) |
XMRstak 2.10.8 (Old Software) - CryptonightGPU - RYO
| 2514.2 Hs | 2615 core / 2000 mem | vcore 1200 / PL 0 | 210 Watt - (Default Timings) |
| 2385.5 Hs | 2450 core / 2050 mem | vcore 1150 / PL 0 | 160 Watt - (Fast Timings) |
| 2094.6 Hs | 2150 core / 2100 mem | vcore 1050 / PL 0 | 125 Watt - (Fast Timings) |
| 1982.5 Hs | 2050 core / 2150 mem | vcore 950 / PL 0 | 120 Watt - (Fast Timings) |
Gminer 2.50 - Equihash 192,7 - Zero
40.57 Mhs 2615 core / 2000 mem vcore 1200 / PL 0 210 Watt - (Default Timings)
