Also I’m mining on mobile connection LTE, which sometimes maybe drops, that would cause a few incorrect i assume, but 700+ in 12 hours thats a lot
try setting the core at 1600 or 1700 and put the memory at 900
let me know what happens
I am now seeing you can go up to 1800 on the core on some of these cards depends on third party manufacturer
them all hangs past 1400 core and 900-930mem
removing everything tho, them does run at 1800 actually, but consumes 180-200W
try 1800 core and 900 mem
that’s where them all crash/hangs, I tried before
so you can do 1800 core but if you set mem clock it crashes?
yes correct, if i remove everything, core included, and let them run as per standard config, them runs at 43-45mh/s average, and 1850 core, as per gpu infos on terminal
so lets leave everything blank and find the best setting for mem without crashing
i should remove everything from core/vdd and only set mem?
yes let’s find what works best here first
the default value i think is about 1000 if i recall correctly, i had posted the results in another thread
I was just looking at them its’s about 875
oh ok, then 1000 was another value
either way, should i try go from 900 and increase or decrease?
I am very surprised that 900 doesn’t work for you that is the only number I can find all over the internet for mem on these cards
I don’t know really, as soon as I put 900 them goes 0mh/s and unresponsive
with everything else blank?
no with vdd setted, i’ll try without vdd now, hold on
ok leaving vdd blank them doesn’t crash, and eats 180W with an average of 52Mh/s and 930mem
