S19 Firmware and odd log entry
I have an S19 and an S19J Pro. I saw the new low power firmware so thought I’d look at that. S19J Pro updated no problem. S19 has no low power mode, but there is a firmware so I tried to up date. Update doesn’t work. Looked in the log and I see I have this:
[ 0.000000@0] **********************************************************
[ 0.000000@0] ** NOTICE NOTICE NOTICE NOTICE NOTICE NOTICE NOTICE **
[ 0.000000@0] ** **
[ 0.000000@0] ** trace_printk() being used. Allocating extra memory. **
[ 0.000000@0] ** **
[ 0.000000@0] ** This means that this is a DEBUG kernel and it is **
[ 0.000000@0] ** unsafe for production use. **
[ 0.000000@0] ** **
[ 0.000000@0] ** If you see this message and you are not debugging **
[ 0.000000@0] ** the kernel, report this immediately to your vendor! **
[ 0.000000@0] ** **
Should that be there? Doesn’t seem like it but there are all sorts of things that are odd about the linux builds on a miner control board that are to be expected.
I’m currently on firmware Wed Oct 20 17:50:59 CST 2021 and trying to get to S19-merge-release-20211216091201-8IN1 which says it’s only for miners currently running later than Oct 15, 2021 - so it should be the correct one to try.
Anyone else have something like that in the logs?
