S19 Hydro - Asic.To firmware!
Anyone here running the s19 Hydro with Asic firmware?
Almost since i got my miner I’ve been running asic.to/vnish firmware-
But now I want to go back, but this seems not really possible!
I’ve tried to take out the sd card, then my miner should go back to stock firmware, and it dose, but it seems currupted. Not working properly.
I’ve tried to install firmware downloaded from bitmain, both the update and recovery versions.
Non work-
Please let me know if you’ve seen similar issue
Thanks
Hey mate, do you know what control board you have? If it’s a 7007 with the sd card slot at the front, then follow this instruction. It’s universal regardless of your miner model, I do the same with my L7 and S19 miners as they use the same control board
Also clear your browser cookies, maybe try that first because i thought it is supposed to go back to Bitmain firmware when you take the SD card out
