Hello after a reboot and a firmware installation my ASIC not hashes and show this:
===========================================Miner log===========================================
2015-01-01 00:00:15 Open miner sn file /config/sn error
2015-01-01 00:00:15 Miner compile time: Tue Feb 20 13:08:32 CST 2024 type: Antminer S19k Pro sn :
2015-01-01 00:00:17 This is fix-freq version
2015-01-01 00:00:17 Miner compile time: Tue Feb 20 13:08:32 CST 2024 type: Antminer S19k Pro
2015-01-01 00:00:17 commit version: e676fcaf 2023-11-18 17:15:18, build by: jenkins 2024-02-20 13:27:14
2015-01-01 00:00:17 opt_multi_version = 1
2015-01-01 00:00:17 opt_bitmain_ab = 1
2015-01-01 00:00:17 mid_auto_gen = 1
2015-01-01 00:00:17 opt_bitmain_work_mode = 0
2015-01-01 00:00:17 port 439 already exported
2015-01-01 00:00:17 port 454 already exported
2015-01-01 00:00:17 port 440 already exported
2015-01-01 00:00:17 port 455 already exported
2015-01-01 00:00:17 port 441 already exported
2015-01-01 00:00:17 port 456 already exported
2015-01-01 00:00:17 port 438 already exported
2015-01-01 00:00:17 port 453 already exported
2015-01-01 00:00:17 port 446 already exported
2015-01-01 00:00:17 port 445 already exported
2015-01-01 00:00:17 Note: front fan is power on!
2015-01-01 00:00:17 Note: rear fan is power on!
2015-01-01 00:00:17 start the http log.
2015-01-01 00:00:17 httpListenThread start ret=0
2015-01-01 00:00:17 start listen on 6060 …
2015-01-01 00:00:17 load machine BHB56902 conf
2015-01-01 00:00:17 machine : BHB56902
2015-01-01 00:00:17 get test_loop_securely_find_asic_num failed
2015-01-01 00:00:17 get high_temp_sub_freq failed,set default high_temp_sub_freq = 10
2015-01-01 00:00:17 get mix boardname[0][BHB56902], name:BHB56902
2015-01-01 00:00:17 bad chain id = 3
2015-01-01 00:00:20 bad chain id = 3
2015-01-01 00:00:22 power off
2024-03-02 20:15:57 ==========================capability start==========================
2024-03-02 20:15:57 board num = 3
2024-03-02 20:15:57 board id = 0, chain num = 1
2024-03-02 20:15:57 chain id = 0
2024-03-02 20:15:57 board id = 1, chain num = 1
2024-03-02 20:15:57 chain id = 1
2024-03-02 20:15:57 board id = 2, chain num = 1
2024-03-02 20:15:57 chain id = 2
2024-03-02 20:15:57 ==========================capability end============================
2024-03-02 20:15:57 chain num = 3
2024-03-02 20:16:00 load chain 0 eeprom data
2024-03-02 20:16:03 load chain 1 eeprom data
2024-03-02 20:16:07 load chain 2 eeprom data
2024-03-02 20:16:07 eeprom load ret:0
2024-03-02 20:16:07 miner:BHB56901,board_name:BHB56902
2024-03-02 20:16:07 miner:BHB56902,board_name:BHB56902
2024-03-02 20:16:07 create thread get_nonce_and_register_thread
2024-03-02 20:16:07 fixed working voltage = 1360
2024-03-02 20:16:07 Chain [0] PCB Version: 0x0300
2024-03-02 20:16:07 Chain [0] BOM Version: 0x0000
2024-03-02 20:16:07 Chain [1] PCB Version: 0x0300
2024-03-02 20:16:07 Chain [1] BOM Version: 0x0000
2024-03-02 20:16:07 Chain [2] PCB Version: 0x0300
2024-03-02 20:16:07 Chain [2] BOM Version: 0x0000
2024-03-02 20:16:07 bad chain id = 3
2024-03-02 20:16:07 Fan check passed.
2024-03-02 20:16:07 init fan pid target=55
2024-03-02 20:16:07 max sensor num = 4
2024-03-02 20:16:07 STATUS_INITED: soc init done!
2024-03-02 20:16:07 temperature_monitor_thread start…
2024-03-02 20:16:14 start to init…
2024-03-02 20:16:15 start up min temp by 75a = 30, limit -25
2024-03-02 20:16:15 i2c_sim_init start
2024-03-02 20:16:15 init gpio477
2024-03-02 20:16:15 init gpio476
2024-03-02 20:16:15 i2c_sim_init end
2024-03-02 20:16:16 power open power_version = 0x76
2024-03-02 20:16:20 power is Calibrated
2024-03-02 20:16:20 power sn:DGQG329BCAJJF0350
2024-03-02 20:16:20 enable_power_calibration,calibration date:211208.
2024-03-02 20:16:22 power type version: 0x0076
2024-03-02 20:16:24 disable power watchdog: 0x0000
2024-03-02 20:16:25 Initializing the power, please wait, this may take up to 2 minutes…
2024-03-02 20:18:25 Slept 120 seconds, diff = 2.
2024-03-02 20:18:35 set_voltage_by_steps to 1300.
2024-03-02 20:18:37 bad chain id = 3
2024-03-02 20:18:37 set_voltage_by_steps to 1500.
2024-03-02 20:18:46 Chain[0]: find 17 asic, times 0
2024-03-02 20:18:48 Chain[0]: find 17 asic, times 1
2024-03-02 20:18:50 Chain[0]: find 17 asic, times 2
2024-03-02 20:18:50 Chain 0 only find 17 asic, will power off hash board 0
2024-03-02 20:18:50 ERROR_SOC_INIT: soc init failed!
2024-03-02 20:18:50 stop_mining: soc init failed!
2024-03-02 20:18:50 uninit_temp_info
2024-03-02 20:18:50 do not read temp anymore…
2024-03-02 20:18:50 cancel thread
2024-03-02 20:18:50 power off hashboard
2024-03-02 20:18:50 temp monitor thread exit
2024-03-02 20:19:18 Version num 65536
2024-03-02 20:19:18 Mask num 0x1fffe000
2024-03-02 20:19:18 Note: addrInterval or corenum is not initialized.
2024-03-02 20:25:11 power off hashboard
2024-03-02 20:25:16 Open miner sn file /config/sn error
2024-03-02 20:25:16 Miner compile time: Tue Feb 20 13:08:32 CST 2024 type: Antminer S19k Pro sn :
2024-03-02 20:25:17 This is fix-freq version
2024-03-02 20:25:17 Miner compile time: Tue Feb 20 13:08:32 CST 2024 type: Antminer S19k Pro
2024-03-02 20:25:17 commit version: e676fcaf 2023-11-18 17:15:18, build by: jenkins 2024-02-20 13:27:14
2024-03-02 20:25:17 opt_multi_version = 1
2024-03-02 20:25:17 opt_bitmain_ab = 1
2024-03-02 20:25:17 mid_auto_gen = 1
2024-03-02 20:25:17 opt_bitmain_work_mode = 1
2024-03-02 20:25:17 port 439 already exported
2024-03-02 20:25:17 port 454 already exported
2024-03-02 20:25:17 port 440 already exported
2024-03-02 20:25:17 port 455 already exported
2024-03-02 20:25:17 port 441 already exported
2024-03-02 20:25:17 port 456 already exported
2024-03-02 20:25:17 port 438 already exported
2024-03-02 20:25:17 port 453 already exported
2024-03-02 20:25:17 port 446 already exported
2024-03-02 20:25:17 port 445 already exported
2024-03-02 20:25:17 Note: front fan is power on!
2024-03-02 20:25:17 Note: rear fan is power on!
2024-03-02 20:25:17 start the http log.
2024-03-02 20:25:17 start listen on 6060 …
2024-03-02 20:25:17 httpListenThread start ret=0
2024-03-02 20:25:17 load machine BHB56902 conf
2024-03-02 20:25:17 machine : BHB56902
2024-03-02 20:25:17 get test_loop_securely_find_asic_num failed
2024-03-02 20:25:17 get high_temp_sub_freq failed,set default high_temp_sub_freq = 10
2024-03-02 20:25:17 get mix boardname[0][BHB56902], name:BHB56902
2024-03-02 20:25:17 bad chain id = 3
2024-03-02 20:25:20 bad chain id = 3
2024-03-02 20:25:22 power off
2024-03-02 20:25:23 ==========================capability start==========================
2024-03-02 20:25:23 board num = 3
2024-03-02 20:25:23 board id = 0, chain num = 1
2024-03-02 20:25:23 chain id = 0
2024-03-02 20:25:23 board id = 1, chain num = 1
2024-03-02 20:25:23 chain id = 1
2024-03-02 20:25:23 board id = 2, chain num = 1
2024-03-02 20:25:23 chain id = 2
2024-03-02 20:25:23 ==========================capability end============================
2024-03-02 20:25:23 chain num = 3
2024-03-02 20:25:27 load chain 0 eeprom data
2024-03-02 20:25:30 load chain 1 eeprom data
2024-03-02 20:25:33 load chain 2 eeprom data
2024-03-02 20:25:33 eeprom load ret:0
2024-03-02 20:25:33 miner:BHB56901,board_name:BHB56902
2024-03-02 20:25:33 miner:BHB56902,board_name:BHB56902
2024-03-02 20:25:33 enter sleep mode.
2024-03-02 20:25:33 power off
2024-03-02 20:27:41 power off hashboard
2024-03-02 20:27:46 Open miner sn file /config/sn error
2024-03-02 20:27:46 Miner compile time: Tue Feb 20 13:08:32 CST 2024 type: Antminer S19k Pro sn :
2024-03-02 20:27:48 This is fix-freq version
2024-03-02 20:27:48 Miner compile time: Tue Feb 20 13:08:32 CST 2024 type: Antminer S19k Pro
2024-03-02 20:27:48 commit version: e676fcaf 2023-11-18 17:15:18, build by: jenkins 2024-02-20 13:27:14
2024-03-02 20:27:48 opt_multi_version = 1
2024-03-02 20:27:48 opt_bitmain_ab = 1
2024-03-02 20:27:48 mid_auto_gen = 1
2024-03-02 20:27:48 opt_bitmain_work_mode = 2
2024-03-02 20:27:48 port 439 already exported
2024-03-02 20:27:48 port 454 already exported
2024-03-02 20:27:48 port 440 already exported
2024-03-02 20:27:48 port 455 already exported
2024-03-02 20:27:48 port 441 already exported
2024-03-02 20:27:48 port 456 already exported
2024-03-02 20:27:48 port 438 already exported
2024-03-02 20:27:48 port 453 already exported
2024-03-02 20:27:48 port 446 already exported
2024-03-02 20:27:48 port 445 already exported
2024-03-02 20:27:48 Note: front fan is power on!
2024-03-02 20:27:48 Note: rear fan is power on!
2024-03-02 20:27:48 start the http log.
2024-03-02 20:27:48 httpListenThread start ret=0
2024-03-02 20:27:48 start listen on 6060 …
2024-03-02 20:27:48 load machine BHB56902 conf
2024-03-02 20:27:48 machine : BHB56902
2024-03-02 20:27:48 get test_loop_securely_find_asic_num failed
2024-03-02 20:27:48 get high_temp_sub_freq failed,set default high_temp_sub_freq = 10
2024-03-02 20:27:48 get mix boardname[0][BHB56902], name:BHB56902
2024-03-02 20:27:48 bad chain id = 3
2024-03-02 20:27:51 bad chain id = 3
2024-03-02 20:27:53 power off
2024-03-02 20:27:54 ==========================capability start==========================
2024-03-02 20:27:54 board num = 3
2024-03-02 20:27:54 board id = 0, chain num = 1
2024-03-02 20:27:54 chain id = 0
2024-03-02 20:27:54 board id = 1, chain num = 1
2024-03-02 20:27:54 chain id = 1
2024-03-02 20:27:54 board id = 2, chain num = 1
2024-03-02 20:27:54 chain id = 2
2024-03-02 20:27:54 ==========================capability end============================
2024-03-02 20:27:54 chain num = 3
2024-03-02 20:27:57 load chain 0 eeprom data
2024-03-02 20:28:00 load chain 1 eeprom data
2024-03-02 20:28:03 load chain 2 eeprom data
2024-03-02 20:28:03 eeprom load ret:0
2024-03-02 20:28:03 miner:BHB56901,board_name:BHB56902
2024-03-02 20:28:03 miner:BHB56902,board_name:BHB56902
2024-03-02 20:28:03 create thread get_nonce_and_register_thread
2024-03-02 20:28:03 fixed working voltage = 1410
2024-03-02 20:28:03 Chain [0] PCB Version: 0x0300
2024-03-02 20:28:03 Chain [0] BOM Version: 0x0000
2024-03-02 20:28:03 Chain [1] PCB Version: 0x0300
2024-03-02 20:28:03 Chain [1] BOM Version: 0x0000
2024-03-02 20:28:03 Chain [2] PCB Version: 0x0300
2024-03-02 20:28:03 Chain [2] BOM Version: 0x0000
2024-03-02 20:28:03 bad chain id = 3
2024-03-02 20:28:03 Fan check passed.
2024-03-02 20:28:03 init fan pid target=60
2024-03-02 20:28:04 max sensor num = 4
2024-03-02 20:28:04 STATUS_INITED: soc init done!
2024-03-02 20:28:04 temperature_monitor_thread start…
2024-03-02 20:28:06 start to init…
2024-03-02 20:28:07 start up min temp by 75a = 35, limit -25
2024-03-02 20:28:07 i2c_sim_init start
2024-03-02 20:28:08 i2c_sim_init end
2024-03-02 20:28:09 power open power_version = 0x76
2024-03-02 20:28:13 power is Calibrated
2024-03-02 20:28:13 power sn:DGQG329BCAJJF0350
2024-03-02 20:28:13 enable_power_calibration,calibration date:211208.
2024-03-02 20:28:15 power type version: 0x0076
2024-03-02 20:28:16 disable power watchdog: 0x0000
2024-03-02 20:28:17 Initializing the power, please wait, this may take up to 2 minutes…
2024-03-02 20:32:17 Slept 240 seconds, diff = 6.
2024-03-02 20:32:27 set_voltage_by_steps to 1300.
2024-03-02 20:32:30 bad chain id = 3
2024-03-02 20:32:30 set_voltage_by_steps to 1500.
2024-03-02 20:32:39 Chain[0]: find 17 asic, times 0
2024-03-02 20:32:41 Chain[0]: find 17 asic, times 1
2024-03-02 20:32:43 Chain[0]: find 17 asic, times 2
2024-03-02 20:32:43 Chain 0 only find 17 asic, will power off hash board 0
2024-03-02 20:32:43 ERROR_SOC_INIT: soc init failed!
2024-03-02 20:32:43 stop_mining: soc init failed!
2024-03-02 20:32:43 uninit_temp_info
2024-03-02 20:32:43 do not read temp anymore…
2024-03-02 20:32:43 cancel thread
2024-03-02 20:32:43 power off hashboard
2024-03-02 20:32:44 temp monitor thread exit
2024-03-02 20:33:00 Version num 65536
2024-03-02 20:33:00 Mask num 0x1fffe000
2024-03-02 20:33:00 Note: addrInterval or corenum is not initialized.
