Unmineable gives you around 1.40 per gh in what ever coin you want.
So you basically you are making less money, but the money is in the coin you want.
Got it. Thanks.
For mining-dutch, does it matter that I’m in the US?
“Our servers are located in Amsterdam the Netherlands, Paris France, Canada and Singapore, Directly connected to the US and the rest of Europe, Russia and Asia.”
I guess “Directly connected to the US” is OK? Was thinking of any latency issues. Should be getting my mini doge II today.
I think if you go to command prompt and type “ping (pool url) it will tell you your latency to the server
I found this handy dandy tool for finding the closest pool.
The problem with ping is a lot of servers have it disabled. From the tool, I learned that dxpool is closer to me. However, I also learned there is an “americas” mining-dutch pool, which is closer, with about half the latency. I may give that a try.
Awesome. Personally closer the better in my experience for the sake of latency, In Australia any pools with servers here my rejection tends to be around 0.1%, Singapore 0.3%, USA 0.5% and Europe well with that latency the server may as well be on the moon lol
