Which of these Helium miners you recommend?
I like the m1 since it has the dashboard.
Thanks a lot for your replies. I hear the antenna on the M1 is kind of weak. Did anyone think the same way?
cheers"
i never used the origianl antenna, so i couldnt tell ya… i used a 3db
