Hi there,
Just found out about this site and really exited about the proswitching mode. Any other setup recommendations to et the best out of it?
As for the coinbase connection, did anyone try it? Is it safe to use?
thanks a lot
Hi there,
thanks a lot
yes. it works fine
You can mess with starting difficulty based on your machine, but I’ve always found that the fewer settings I mess with, the better it works.
I’ve had my account connected to coinbase for years, and it is totally safe, and actually really nice, because you can get you earnings transferred to coinbase without any fees.
