Solar/PV Mining
Hello All
Looking for some advice, Im coming at this from a different angle. By day job, I/we have develop over 100mw of ground mount systems in 2022. Cutting to important part, Im in a unique position to have free/very little impute costs into my Solar system. Considering a 250kw ground mount system, already have the land/panels/rackng in PA.
Would like to do immersion system…
What miners would you suggest? I can over clock to the max …electric is free.
Well, you cant really go wrong with s19xp hydros if you have free electric. Although honestly, anything will make money with free electric.
With free electricity I would go with most energy consuming miner that yields reasonable earnings. The reason why I suggest that is because most miners that use a lot of energy but earn little profit tend to cost very little and are usually in stock. Think about it; who wants to buy a miner that earns $10 daily but cost nearly the same amount to run.
The most important factor in your solar setup is having adequate battery storage. Even the most elaborate solar systems can be counterproductive if there’s little to no storage of energy.
That sounds awesome and sounds like you know what you’re doing for the solar!
If you went hydro I would just double check how good they are I thought I heard a little birdie say they are breaking down easier then other models. Keep in mind if you have good cooling and OC a S19J pro it is only $10.70/TH on stock PSU and $9 if you get a custom PSU and OC it to the max
I will confirm this early next week when my control board for overclocking comes but currently I found this screenshot from someone on reddit https://imgur.com/a/cPCDhus/
