I am selling parts of my gpu rigs to customers, I want to have separate wallets for separate gpus. For example:
6 gpu rig
Mining ETH
3 gpu rewards will be sent to one wallet, say wallet id 1234
3 gpu rewards will be sent to one wallet, say wallet id 5678
How to do this?
There’s really no way you can have all GPU’s running on the same motherboard but sending to different addresses simultaneously. You need two sets of software with separate addresses attached to each of them but it doesn’t matter because two separate mining softwares cannot be executed at the same time. Your best bet is to build another rig and divide the GPUs, or alternate software with the given wallet address. If you’re handy computers you can set a program timer for one software to shut down and the other to execute daily.
Side note: there could possibly be a dual mining software out there that uses the same algorithm but switches users or “wallets”. I’ve never seen it though
