St box referring to asicminervalue.com should make 4-5$ Daily profit while in reality it is barely making 18-20 coins daily 1.6$ what is happening
Hard to say, lots of questions:
-what is your hardware rejection rate?
-what is your mining pool rejection rate?
-what is your avg hashrate compare to ST box spec hashrate?
-If everything is to spec or within tolerance, then ASICminervalue.com is off
Does â4-5$â mean â$4-5â? (one is correct, one is not)
I am having the exact same question. Itâs barely making 18-20 coins a day and the the coinâs current price is $0.1 which makes it $2 a day at most.
My rejection rate is 2-3% and HW error is 0.03%, so not sure whatâs happening.
Goldshell reports the ST-Box as producing 13.92 kh/s. If I input that into Dxpoolâs STC calculator it shows only $1.80 and that is before electricity (of which ST-Box doesnât use much but still).
I donât know where asicminervalue gets its calculations from but it isnât always right. For instance just a few weeks ago it said HS-Box was making a negative amount daily when it was more like $2.50.
Daily Profitsďź
13.92 KH/s â 18.77442391 STC $1.8061
I am using dxpool
Rejection rate is 2-3% max
Hw error is 0.3%
i just update to 2.2.0 on my two STC boxes and iâm still getting a 3-4% rejection rate. i am guessing the numbers are normal? does anyone have better results wuth different firmware? TIA
