Is the IceRiver KS0 Pro still worth buying, is it really the best mini miner for 2024, being a small, quiet, and profitable mining rig earning easy passive income from home mining the 2nd most profitable coin to mine after Bitcoin?! Is it really that simple?? Vincent of VoskCoin, reviews! Grab one here - https://voskco.in/ks0pro
I bought this IceRiver KS0 Pro here - https://voskco.in/ks0pro
Use code voskks0 to save some coin!
Buy the KS0 Pro from IceRiver w/ code VOSKCOIN - ICERIVER
More IceRiver KS0 Pro stock here! https://voskco.in/ks0pro
Shroud for overclocking KS0 and KS0 Pro - Cooling Grills & Shroud β The Meter Box
use code VOSKCOIN to save some coin!
Check Out the ULTIMATE ASIC Mining Guide - https://youtu.be/UvmXso0h3Oo?si=cyMVvb69XT3bqxsi
Check Out our KS0 Review! - https://youtu.be/zQOgQVWXdPA?si=5llqoJuSoiH_Emf3
Buy other mining rigs from ASIC Marketplace! https://voskco.in/am
Vincent is one of the VoskCoin video editors and an avid miner, so he is stepping up to review his very own IceRiver KS0 Pro evaluating the mining profitability, the future of Kaspa KAS, and if itβs still worth it to get into Kaspa mining in 2024!
00:00 Is the Ks0 Pro a miner you should buy?!
00:50 Bitcoin and Ethereum mining
02:00 Kaspa revived gpu mining
02:52 The Ks0 pro, a good home miner?
04:00 How to set up a Ks0pro Kaspa miner?
05:36 Where to buy a ks0pro?
06:30 How much electricity does a KS0pro use?
08:32 How much profit can you make mining with the Ks0 pro
10:00 Kaspa to the moon?
Still The BEST Mini Miner for 2024? Iceriver KS0 Pro Worth It?
