General Info Of Team Red Miner
Team Red Miner or TRM for short is one of the most productive manners for AMD graphics cards. The miner runs on Windows and Linux operating systems. Team Red Miner works with almost all cryptocurrency algorithms, mining of which is carried out on video cards. The standard commission manner for most algorithms is 2.5%, for Et hash 1% for Navi/Vega graphics cards and 0.75% for Polaris. TRM successfully works with video cards with a 4GB memory capacity on Ethereum, even after the size of the DAG file has exceeded 4GB. At the same time, as in the case of other programs, mining goes with a reduced hashrate.
With the latest versions, it includes rewritten Ethash cores and new mining modes for all types of GPUs. This means that you should get a better hashrate with slightly less power consumption on the most recent AMD GPUs. In general, Team Red Miner (TRM) behaves similarly to other AMD Temash manners, the key difference is additional mining modes (B/C modes) that use additional VRAM on GPUs for further positive effect.
SUPPORT LEGEND:
Y = Supported
N = Not supported
L = Limited support: algos are supported on windows and linux with amdgpu-pro drivers, not supported on ROCm drivers.
GPUS SUPPORTED AND TESTED:
Navi – RX 5700(XT)/5600(XT)/5500(XT) for supported algos in the table below.
Big Navi – RX 6900XT, RX 6800(XT), RX 6700(XT), RX6600XT – same support as for Navi.
Vega – RX Vega 64/56, Vega FE, Radeon VII (Vega 2)
Polaris – RX 580/480/570/470/560/460/550
Fiji – R9 Fury/Fury X/Nano, MI8 (supported but with very limited testing).
Tonga/Antigua – R9 285/285X/380/380X, W7100, S7150 (beta support from 0.8.2. Only ethash+kawpow available.)
Download the latest version:
Windows: teamredminer-v0.10.2-win.zip
Linux: teamredminer-v0.10.2-linux.tgz
Linux: teamredminer-v0.10.2-linux-armhf.tgz
README highlights:
- GPU: Tweaked Polaris ethash tuning to work better with the new smooth-power setup.
- GPU: Fix for Autolykos crashing on Polaris and 4GB GPUs.
- GPU: Fix for Eth+Ton dual mining crashes with new smooth-power setup.
Main executable file hash info:
Windows binary checksums
SHA256 teamredminer.exe e35abaee6131910e4a8753ebba74c2a3628714db379a33373bb6913f88371c9c
MD5 teamredminer.exe 8915d11eff42e75983159947a9c1e748
Linux binary checksums
SHA256 teamredminer a138bbed75361838f9e1c26e1d1167619a2393e40821731610b5cee585fec7ae
MD5 teamredminer 9351169eeebda5d277ace3033b1fb071
Linux armhf binary checksums
SHA256 teamredminer bdd452d50b3735e8d6e14ab144fcd0c0f24a4e93d5e31419953fb543c69942fd
MD5 teamredminer 2e6c9e44739f84342ba0372831854fa3
Polaris
Nitro+ 580 8GB Samsung, core 1150@840mV, mem 2100@840mV, ref 30
| Version | Mode | Tuning | Hashrate | Power | Diff vs 0.7.21 |
| 0.7.21 | A-mode | A256 | 30.73 MH/s | sensor 79.66W | |
| 0.8.0 | A-mode | A194 | 30.97 MH/s | sensor 78.25W | -1.41W |
| 0.8.0 | B-mode | B232 | 31.13 MH/s | sensor 78.77W | -0.89W |
Vega 56/64
Vega 56 ref Samsung, A-mode 1065@850mV, B-mode 1000@850mV, mem 950@850mV, TRM timings
| 0.7.21 | A-mode | A872 | 50.08 MH/s | sensor 115.98W | |
| 0.8.0 | A-mode | A448 | 50.32 MH/s | sensor 111.15W | -4.83W |
| 0.8.0 | B-mode | B450 | 50.31 MH/s | sensor 110.15W | -5.83W |
Radeon VII
Radeon VII Hynix, core 1600MHz@881mV, mem 1000MHz with timings
| 0.7.21 | B-mode | B740 | 87.87 Mh/s | sensor 185.25W | |
| 0.8.0 | B-mode | B208 | 87.85 Mh/s | sensor 177.38W | -7.87W |
| 0.8.0 | C-mode | C322 | 100.4 Mh/s | sensor 192.54W | +7.29W +12.53Mh/s |
5700/5700XT
Red Devil 5700XT Micron A-Mode 1400@725mV, B-Mode 1245@675mV, Mem 912 MHz
| 0.7.21 | A-mode | A624 | 56.05 MH/s | sensor 105.82W | |
| 0.8.0 | A-mode | A620 | 56.08 MH/s | sensor 103.61W | -2.21W |
| 0.8.0 | B-mode | B608 | 56.01 MH/s | sensor 96.83W | -8,99W |
MINING POOLS
Awesome Miner can be used with any mining pool. The list below includes the predefined pools to make it easier to get started with mining on the most popular pools.
| Algorithm | Pool | Algorithm | Pool | Algorithm | Pool | Algorithm | Pool |
| Argon2 | IceMining – NIM | Lyra2REv3 | NiceHash – Lyra2REv3 | X16r | Zergpool – X16r | X16r | Pickaxe.Pro – XGCS |
| Autolykos2 | NiceHash – Autolykos2 | Lyra2REv3 | Mining Pool Hub – Lyra2REv3 | X16r | Block Masters – X16r | X16r | Pickaxe.Pro – XRD |
| CryptoNight Haven | Zergpool – CryptoNight Haven | Lyra2REv3 | BSOD – VTC | X16r | BSOD – BITC | X16rt | BSOD – GIN |
| CryptoNightV4 (CryptoNightR) | NiceHash – CryptoNightV4 (CryptoNightR) | Lyra2z | NiceHash – Lyra2z | X16r | BSOD – CXC | X16rt | BSOD – VEIL |
| CuckaRood29 | NiceHash – CuckaRood29 | Lyra2z | Mining Pool Hub – Lyra2z | X16r | BSOD – EXO | X16rt | Pickaxe.Pro – GIN |
| CuckaToo31 | NiceHash – CuckaToo31 | Lyra2z | Zergpool – Lyra2z | X16r | BSOD – FXTC | X16rv2 | NiceHash – X16rv2 |
| EtcHash | Mining Pool Hub – EtcHash | Lyra2z | Block Masters – Lyra2z | X16r | BSOD – HLX | X16rv2 | Mining Pool Hub – X16rv2 |
| EtcHash | Zergpool – EtcHash | Lyra2z | BSOD – FXTC | X16r | BSOD – HTH | X16rv2 | Zergpool – X16rv2 |
| Ethereum | NiceHash – Ethereum | Phi2 | BSOD – AGM | X16r | BSOD – JINY | X16rv2 | NLPool – X16rv2 |
| Ethereum | Mining Pool Hub – Ethereum | Phi2 | BSOD – LUX | X16r | BSOD – RVN | X16s | Zergpool – X16s |
| Ethereum | Zergpool – Ethereum | Phi2 | Pickaxe.Pro – LUX | X16r | IceMining – BITC | X16s | Block Masters – X16s |
| FiroPow | Zergpool – FiroPow | Phi2 | Pickaxe.Pro – AGM | X16r | IceMining – PHL | X16s | BSOD – PGN |
| Kawpow | NiceHash – Kawpow | Phi2 | Pickaxe.Pro – SPDR | X16r | IceMining – RVN | X16s | BSOD – XSH |
| Kawpow | Mining Pool Hub – Kawpow | Verthash | Mining Pool Hub – Verthash | X16r | IceMining – XRD | ||
| Kawpow | Zergpool – Kawpow | Verthash | Zergpool – Verthash | X16r | Pickaxe.Pro – MDEX | ||
| Kawpow | NLPool – Kawpow | X16r | NiceHash – X16r | X16r | Pickaxe.Pro – RVN |
