The best mining pool & how will i know if i hit a bitcoin block
Hello, I’m a newbie here & a newbie to mining.
My beginner questions are what are the best websites to find a solo pool and which pool to use?
Second question is, how will I know if I score Bitcoin?
here is one of the best sites to look for pools https://miningpoolstats.stream/
as for knowing if you hit a block, you will just have to check your wallet. if your solo mining with less than a few 1000 TH the chances of you hitting one is tiny so dont get your hopes up.
