Hi everyone
Looking for some advice please.
What thickness thermal pads should I buy for 8gb RX580 and RX570 cards please.
I replaced thermal pads on my Saphire RX570, but it’s now worse than before.
Just want to do it right and save my cards the heat stress
Thanks
Hi there!
I think I may be able to help…
First off what temperature heating are running them cards on?
Normally my card run at 60 to 65 degrees, 80% fan.
The Saphire cards are climbing to 80 now. I am seeing other cards temps moving towards 70.
I think it’s time for pads n paste. But what’s the right thickness, that’s my main problmem
You don’t want them to be too thick, keep it at a standard size.
However I will advise you want to try keep your cards under 70 to be safe not just for the GPUs, but to help last your thermal pads longer too
