Thinking of buying mini dogeminer (compatibility(
Does goldshell mini dogeminer have a compatibility ? Thinking of buying it ! I own a HP Slim S01-aF0006b Desktop PC Bundle, 23.8" Screen, AMD Ryzen 3, 8GB Memory, 256GB Solid State Drive, Windows® computer
What are you specifically asking? I’m confused by your post.
The MINIDOGE does the work. You are just connecting it to your network and setting it up through its IP address. You link your wallet, get into a POOL, and off you go. You can use your CPU and GPU from your computer to possibly mine a small amount of BITCOIN on NICEHASH or use unmineable. Use both machine to make some type of crypto so you are not wasting energy. There is a great video on the VOSKCOIN youtube page that will give you all the instructions. It helped me get mine setup and I have used the older videos to get prepared for my GPU rig I am assembling. I currently have a Nvidia Geforce GTX 1660S in my SKYTECH ARCHANGEL gaming computer, with an AMD RYZEN 5 3600 6 core processor. Have it mining on NICEHASH.
