Your input was helpful I tried the hard reset and reset the ip address aswell but had no luck.
Have you came across a Goldshell that become inactive after 15 minutes?
I have upgraded the Firmware version2.2.1 Hardware version 30.40.A6
Upgraded firmware successfully, change power cord, change PDU power cord.
, Restarted 3 times, change Pool setting several times, change network cable, and It still become inactive after 15 minutes. It states (Miner pool is not ready yet) would you know what else I can try? Greatly appreciate any help. Thanks
So my two are wifi, I held the recessed button on the back of the miner and I guess that is a factory reset. That allowed it to get a new IP address so I could connect my computer to the miner and set it up. The first time I did this it went online then fell off an hour later. The only thing I could think is I didn’t change the factory password. The second time I changed the password and it has been running for days.
ez4009
Go into miner software turn off WLAN in the WI-FI settings as in the picture here that should be off all the time once you have configured your miner.
This should work 100% let me know if it worked.
Joel_Shaw
Do you run yours on wi-fi all the time?
Yes on wifi
Why not on Ethernet never miss a beat .
Wifi seems to be ok, does it affect hash rate? I can wlan them really easy but everything I watched says no need
With wi-fi you do get black spot here and there thats when your are not mining.
I get them all the time even with 1.1GB service that’s why I have wired connection everywhere even the Garden inc WI-FI.
Thanks for the input, but mind does not have wifi.
I would agree with SinghisKing, go with hardwire, your best option reliable.
Mind does not have wi fi setting.
Thanks for your input, I’m trying to get Gold shell support to help I did not see a phone number call for tech support looking for ASiC repair shop that could help or something.
Thanks
That’s my just getting started miners! I appreciate the info I am learning!
Very nice Joel_Shaw looks like disco party to celebrate
