Umbrel bitcoin node Public-Pool 100% synced
cannot connect Nerd Miner Version 2 miners to pool
Have tried multiple Nerd Miners, using default info from Public-Pool
TCP adress 192.168.0.70:2180
MINERS ARE NOT LATEST VERSION OF SOFTWARE version 1.6.3 original burn
do I have to upgrade to latest version ?
I have 1.6.3 have tested 1.7.0 1.7.1 1.8.0 nothing seems to work, can log in to public-pool.io and have them mining on it but not able to use on my own node
same problem using esp32 wroom 32 chips, will not work on umbrel node under public-pool, will work on public-pool.io, i have maybe 100 of these chips on breakout boards, 12 volt power supply, they are on their own router
Have 14 on duino coin have been mining for 2 years on them , I am using 2 8 port powered usb hubs uisng usb c connection on breakout board
