Currently got un mineable. Mining ETH it’s not mining any thing . It’s on a low intensity .
What settings should it be or un mineable doesn’t work ???
ETH went PoS ages ago. Unless you meant ETC or some other ethash algo coin?
If you did mean ETC generally the more inexpensive/older miners don’t actually mine because the DAG file is too large. All ETC miners have storage space. If your unit is less than 4GB currently it wont mine.
What are you mining with and are you mining to get paid out in ETH or are you trying to mine the ETH algorithm? I haven’t used unminable but as I understand it works akin to Nicehash in that it mines something to a pool but it pays you in the crypto of your choice primarily cryptos that are not minable.
Hey PirateSeuld. Currently mining with cpu . Trying Bitcoin cash. It’s getting there slowly ![]()
