Z15pro, an upgraded version of the ZEC mining server Z15 just launched by Bitmain, it is available for preorder on Apexto official website now. Antminer Z15pro is Bitmain’s fourth generation mining machine based on the EquiHash algorithm. The EquiHash algorithm is mainly used for Zcash mining, and can also be used for mining other currencies using the EquiHash algorithm.
Specification:
MANUFACTURER | Bitmain |
MODEL | Antminer Z15 Pro |
ALSO KNOWN AS | Zcash Miner Z15 Pro 840KSol |
RELEASE | June 2023 |
SIZE | 245 x 132 x 290mm |
WEIGHT | 5900g |
NOISE LEVEL | 75db |
FAN(S) | 2 |
POWER | 2560W |
INTERFACE | RJ45 Ethernet 10/100M |
TEMPERATURE | 5 – 40 °C |
HUMIDITY | 10 – 90 % |
The Z15pro 840K uses a parallel dual-fan single-row air supply and heat dissipation design. The mining machine can be placed upright or flat according to the rack of the mine. However, according to the size, the rack with a height of 25cm in the mine can only be placed flat, please.
The protective cover of the Z15pro 840K is also a snap-on design and is fastened with screws to prevent accidental opening of the protective cover. Remove the screw of the protective cover, press and hold the button and push it up to open it. This step is also required when connecting the power cord operate.
Conclusion:
The miner is light and and easy to operater. It is safe to investment .The Chinese name of zcash is ZEC, which is a digital currency based on zero-knowledge proof. Zcash On the premise of protecting privacy, users can decide to disclose some information on their own, such as choosing to hide the currency receiving address, transaction information or balance, etc. Zcash can realize economical and fast and reliable transfers. If you are interested please feel free to contact with our Apexto sales team.
