Good day to all. The question that i have is regards to a vendor that will accept payments via a crredit card. I have moce than enough room on my business credit cards, ( I do not have any bags associated with the business and the credit card companies do not allow for any type of scrypto purchases). I am willing to add a merchant fee to the sell price ( with in reason). Any recommendation would be most helpful.
On a side not - in an effort to get the most bang for one’s buck , what would be your recommendation for a kaspa miner - Antminer, Ibelink, winsminer, or iceriver? Amd wjy?
@Hudpog sent me a picture today of his Iceriver KS3m power supply blown up.
The more I learn about how these machines functions, the more I understand why people go immersion cooled over air cooled or water cooling plates. You have these tiny pieces that have no heat sinks that will fail when the board gets hot or even the tiniest obstruction such as dirt or if the air flow isn’t right. If you’re buying a new gen machine I’d strongly suggest immersion cooling, next I’d suggest water cooling plates with a radiator that’s 3-4 X the KW output (example 3kw miner, 12kw radiator, with one set of fans still running) or 2 X 800 CFM fans with shrouds covering the PSU with a dust filter. Just view it as insurance
I’ll vouche for @badgerlandcrypto. But fyi you can order ASICS on Newegg these days. And even Amazon. But look into paying vendors with crypto, because it’s likely cheaper.
If you can avoid the tariff I’d say use the manufacturers themselves. If you can’t, use Bitmars. Great experience with them and the prices are usually the best around.
