Wallet for ALPH mining
can I mine ALPH directly into an wallet at coinex and does it make sense? Or do I need the alephium wallet?
You can, but you shouldn’t. If you do, make sure you adjust the payment threshold so the pool isn’t paying out every hour or so. Once a day all you want it you mine to an exchange. You should get the desktop, extension, or mobile wallet from the project site - https://alephium.org/
just curious, is there a reason to only have it payout to an exchange once a day?
Didn´t say once a day.
In my case it is that I just dont like to install a separate dedicated wallet for every coin I get in contact with.
Because Koinly charge per transaction to do your taxes - and the exchanges might ban you if you send micro transactions every 30 minutes like coiminerz do for LCN when it’s merged mined with KCN. You can’t change the payout on the LCN - only the KCN. Daily is a matter of convenience and cost reduction at tax time for me. I can’t think of a reason why I’d want it faster.
Once you’ve mined to an exchange that disappears, you will probably find you don’t mind getting the project wallets quite so much.
Or maybe they might just freeze withdrawals.
Exchanges are great for exchanging. Not so great for parking things up.
i guess that makes sense.
