Hey all,
Very new to this and will try to explain with out confusing in the process.
So I bought my first mining rig, set it up and all is running ok.
Please see the Mining Rig specs:
Motherboard - GIGABYTE GA-H110-D3A
Processor - Intel Celeron CPU
RAM - DDR4 Crucial 8GB RAM
256GB HDD
Power Supply 1000W EVGA PSU
Now the 1st GPU that came with this is a 3 Weeks Old Sapphire AMD Radeon RX580, works perfectly fine when being used.
However today I recently received my 2nd GPU I bought from eBay which was another Sapphire AMD Radeon RX580 (but this one is the light blue casing Special Edition.
After connecting the right VGA cables between the 2nd GPU and the PSU and also connecting the 2nd Riser to the PSU via a SATA cable, I switch the PSU on and the power cuts off literally after a second.
I panicked thinking I killed the mining rig but when I put it back to just powering with just 1x GPU, it works perfectly.
If somebody can tell me what I am doing exactly wrong and advise how I can resolve then I will highly appreciate this.
Really sorry, very new to the mining GPU nd something tells me I should of built one from scratch but wasn’t confident…guess you can call me a ‘stupid noob’/
Look forward to your suggestions and thanks again.
