Im overseas at the moment and had a message from my wife to say that our Linxdot just arrived.
It should be a 915Mhz but the photo sent to me was a bit confusing.
Is the 865mhz crossed out or is that a tick? Same on the back of the unit.
Hope its a 915mhz as I need to post it to my friend this week.
Thanks
Mike
Some vendors do it differently. It could be a 915. I’ll ask around to see what others may look like!! I’ll get back to you
Hi Michael
I think you got the right one I just bought mine I am in UK and its model number is
LD-1002 your one is LD-1000 so it must be 915Mhz but check with their support team.
Thanks
I sent support a message a couple of days ago but they must be busy this week.
Had good contact with them over the last 3 weeks as this unit was due to a mistake in shipping orders.
They sent me someone else’s fed ex order and I contacted them to let them know the details were wrong. (My order was not due for another couple of batches)
Any way, for good will they sent me a unit early. It was sent to my UK address from the UK depot (Not Hong Kong)
My order was for a 915Mhz unit as I will send it to the Philippines. Hope they get in touch before Tuesday before I send it off.
Thanks again
