Alright, imagine this solo mining is when you’re mining crypto all on your own instead of teaming up with a pool. The cool part? If you actually hit a block, you get to keep the entire reward. Pretty awesome, right? The tricky part is that it’s a bit risky because whether you succeed really depends on your hardware and how tough the network is at the time.
If you’re thinking of giving it a try, having good hardware helps a ton. A solid miner can seriously improve your chances of landing those full rewards.
And honestly, if you want some tips or tricks to make it easier, the ASIC Marketplace has some really useful stuff you should check out.
