Just got my S19j Pro 104T. Been using F2Pool for my mini Doge miner and NICEHASH for my GPU miner. What are your recommendations for my S19j? Should I use F2Pool and merge mine? What is the most profitable with the best stability?
I merge mine with my S19j Pro 96TH on f2pool.
Have you tried another pool?
I do have SlushPool, Poolin, pool.btc.com, and DxPool, in addition to my f2pool.
With f2pool I get the BTC plus transaction fees, plus VCASH, Hathor, Namecoin, and Elastos, gramted that we are probably speaking of $1 or $2 dollars extra, but something is something I guess.
Plus everything is in one pool, which makes it easy for taxes.
I was wondering that as well. Gotta love the taxes.
Yep, to keep it simple, I only use f2pool for now.
I might change in the future but lets see.
Where can I find wallets for the 4 other coins?
Hathor has it’s own iOS app, for VCASH I use the BigONE Exchange, for Namecoin I use the Coinex Exchange, and for Elastos I use my Ellipal Titan hardware wallet, which happens to have support for that coin.
Much appreciated. I was looking around last night but was worn out from the excitement and did not get much research done.
i use viaBtc for a mining pool because there are no withdrawal fees if you use coinex exchange. Plus its a daily payout and i can also do an instant withdrawal for free at any time. Coinex is the exchange they use so it is a member to member transfer so there are no fees.
i like to keep things simple. f2pool all the way with mining btc
ok, i am trying to set up my S19J pro 104T and I feel like i do not have the mining address right. how should it look when entering it for a North American Pool
Does anyone have any miners with Compass mining? Because I’m thinking of letting them host this S19j Pro miner for me Thoughts?
I do, I have one S19j Pro 96TH Mining with Compass since Oct 26! I also have 2 L7 scheduled to go online and Mining with Compass by Jan 10.
So far for my mining pool I use f2pool for the merge mining, and also for the easy to use interface.
thx bro saving up for one right now, just recently got into all this.
